02 raptor -Jetting Recommendations(pipe, filter, ported, cam etc etc)
Old Sep 21, 2005 | 03:36 PM
jerstilly's Avatar
Default 02 raptor -Jetting Recommendations(pipe, filter, ported, cam etc etc)
I recently got my motor( 02 Raptor) worked on by Kenz, port job, stage 2 cam, new valves(stock size),101mm (673 cc), 11:1 HC piston, I am currently running a full sparks X6 exhaust, Pro flow w K&N filter, air box lid removed, running at approx 1200 ft...my current jet sizes are 160/165, 25 pilots, gytr needles on 3rd clip, about 3 turns out on ea fuel/air screw. With the new work being done what should I be starting out at with my new jetting. Thanks A Lot. gytr jets. I have from 170 - 190 also got some 27.5 pilots.
Old Sep 21, 2005 | 03:48 PM
sixsixT's Avatar
I would start with the biggest ones you have.
Old Sep 21, 2005 | 04:26 PM
jerstilly's Avatar
thanks sixsixT, you have been a great help before when i just got my pipe and you got me spot on, so hopefully this time the same, also would you put in the 27.5 pilots as well?? and how many turns out would you figure? thanks again
Old Sep 21, 2005 | 06:56 PM
sixsixT's Avatar
I've never used the 27 pilots but I would guess about 2 turns out if you do.
Polaris-400
Aug 19, 2015 02:20 AM
bpegram84
Jul 22, 2015 08:15 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
