Drag 700r vs 660r raptor
Old Sep 25, 2005 | 11:25 PM
  #21
Air's Avatar
Air
Default Drag 700r vs 660r raptor
You are right. I actually do relativly little Hill shooting. I prefer a fast paced ride through the dunes. Or a nice ride through the mountains. I can tell you from personal experiance that a carbed raptor doest like starting at 4500 ft and going to 11500 in a short time without jetting. My DS was real forgiving on jetting but I have yet to be with a 660 rider that was happy by 8000 ft. The Injection is awesome for trail riding. If I was only going to ride the dunes I would have put more $$ into the DS.
Old Sep 25, 2005 | 11:36 PM
  #22
HappaRap's Avatar
Lazy Boy Rider!
Originally posted by: Air A Honest opinion from someone to have owned both.
The 700 has issues above 6500 rpm.
Would a different cam solve that problem? Maybe bump the compression up as well?
Old Sep 25, 2005 | 11:55 PM
  #23
Air's Avatar
Air
Cam, compression or maybe even an ignition, Most likely a cam though.
Old Sep 25, 2005 | 11:56 PM
  #24
Trxoutlawz's Avatar
I really think a cam and maybe a higher compression piston could be the answer if you really want to be able to rev more and trying to just make more out of the bike.. Also, how about porting.. Just a thought..
about the origonal issue..
I think the farther you go on any machine you start making that machine one dimensional.. That is what happens out this way at Sand Mountain with banshees mostly, but I have seen others.. You put $ after $ into it and it becomes a hill shooter, or drag racer only.. You cant just jump on it and go duning,, Well I think the 700r hit the most points with me because of the handling, power, no more jetting, and all around riding that gets done by me in the conditions that I ride in.. I can go from 5000' to 12000' in the same days ride, now that is why the FI appeals to me.. A carbed bike will not like that trail ride, I know,, I was there.. even with a dial-a-jet..
now back to the drag racing.. . You could make any bike beat any bike as long as you got money... As for a stock 660 and a stock 700, 700 wins all the time, bike to bike..
Enjoy your drag racing, there is always someone faster........
Old Sep 26, 2005 | 12:30 AM
  #25
CTracingraptor's Avatar
see but your defination of trail riding is far from mine. just because of the terrain. You idea of trail riding is going up hill huge elevations, my idea of trail riding is flat area. I think your a forest and im a desert rider. I though about selling my rap for a 700r, but after last night im sticking with my rap. You right give it time and it will excel. 660's came out in out, and builders are still trying to get the kinks out, and make more power. ever few months another 660r comes out with more power, more torque, or a larger bore. That was 5 years ago and they still have a lot to learn. Im sorry but waiting 5 years for the 700r to come around with technogly is to long for me. Not saying that within the year, theor wont be a big-bore, cam and port job available. but i assure the first ones available are going to be as good as the ones 5 years down the road.
Old Sep 26, 2005 | 12:39 AM
  #26
Trxoutlawz's Avatar
I agree with you on atleast one thing.. No two peoples idea of riding are ever the same and nobody has the perfect ride for everyone.. Yes my trail riding consists of mountains, I also do a lot of desert riding and I play on the sand.. I like shooting the hill at the dunes and the drag racing, uphill or flat.. But that is not all, if it was I would never have sold the Banshee... For me and what I like to do and how I like to ride, the 700R made very good sense.... The handling is by far much better than the 660's. That meant alot to me also..
Old Sep 26, 2005 | 02:35 AM
  #27
RoostItUp's Avatar
A good cam will definitly be what you want if you want more power in the higher RPM's. The Hotcam stage 2 will give you power up to 6,800-7k RPM, but you need to replace valve springs for that. I don't think the stage 1 cams raises the RPM performance nearly as much. The 660's didn't ever make any power over 6,500 either unless you installed a better cam, but after looking at your dyno chart again your 700 looks like it's only making power up to 6,200 RPM. Looks like Yamaha decided to sacrifice a little top end for an increase in torque, I bet this really helps it as a trail machine. The 4 valve head would also help in the torque department and could be another bottleneck to the lower peak RPM. Another thing to consider is new ignition, but if the bike doesn't make good power when being revved than increasing the RPM rev limit probably won't help to much. The improved ignition curve might help, but nothing like what a cam will do.
Old Sep 26, 2005 | 03:18 AM
  #28
Webopper's Avatar
I still want to see a dyno run of a 660 with a slip-on and a air filter...
Maybe not exactly what you are looking for, but should give you a good idea of where the 660r is piped, jetted and airboxed with all the different manufacurers...I came across it doing some research. It looks like it was done by dirt wheels a while back and not the easiest to read though...basically, what they did was take the pipe manufacturers recommedations for jetting and airbox mods, install the pipe and run the dyno. Jetting and airbox mods listed first, dyno below that. Whole article is here.
BRAND/ MATERIAL/ headpipe/muffler /SA TYPEHARDWARE /JETTING/ RECOM AIR-BOX MODS /PHONE
Stock Steel/steel Baffle Bolts 140/145 Stock Dealer
Alba Coated mild steel/steel Disc Allens 145/150 Remove snorkle (858) 486-4380
Big Gun Ctd mild steel/plshd alum Screen Allens 155/160 Remove snorkle (909) 948 7029
Bill?s Pipe Coated mild steel/alum Screen Allens 155/160 Remove snorkle (909) 371-1329
CT Sonic Coated mild steel/alum Disc Bolts 170/175 Remove lid (562) 945-2453
Sparks X-6 Coated mild steel/alum Disc Allens 146/148 Trim snorkle (661) 872-4343
FMF Power Core IV Mild steel/alum Screen Allens 155/160 Remove snorkle (310) 631-4FMF
Graydon Proline Ctd mild stl/anodized alum. Screen Bolts 165/170 Remove lid (562) 531-7142
Pro Circuit T-4 Stainless steel/alum Screen Allens 150/155 Stock (909) 738-8050
Trinity Stage IV Chrome mild steel/alum Screen Allens 155/160 4" sq. hole, no snorkle (714) 632-3434
White Bros. E Stainless steel/alum Disc Rivets 142/146 Trim snorkle (714) 692-3404
White Bros. R Stainless steel/alum Screen Rivets 142/146 Trim snorkle (714) 692-3404
Yoshimura Tec-SA Stainless steel/alum Screen Allens 150/155 (2)1-3/4" holes, no snorkle (909) 673-1060
HP and Sound
BRAND 4000rpm PEAK HP LEVEL WEIGHT PRICE
Stock 22.1 35.6 @6500rpm 92db 13lb $495
Alba 32.3 46.1 @7400rpm 102db 12.71lb $349
Big Gun 27.6 43.3 @6250rpm 102db 8.23lb $499
Bill?s Pipe 28.5 42 @6500rpm 101db 7.75lb $439
CT Sonic 32.6 48.6 @7100rpm 103db 11.25lb $589
Sparks X-6 29.9 44.6 @7100rpm 102db 10lb $489
FMF Power Core IV 31.1 43.9 @6800rpm 102db 8.16lb $490
Graydon Proline 28.9 47.3 @7100rpm 103db 10.61lb $439*
Pro Circuit T-4 30.1 42.9 @6300rpm 102db 7.16lb $520
Trinity Stage IV 29.2 46.5 @6800rpm 103db 10.82lb $560
White Bros. E 32.1 44.9 @6300rpm 102db 9.5lb $520
White Bros. R 29 44.1 @6300rpm 102db 7.61lb $480
Yoshimura Tec-SA 29 46.2 @6500rpm 100db 9.41lb $519
Old Sep 26, 2005 | 03:30 AM
  #29
ah the infamous dirtwheels pipe shootout from 02. I think we've all got this issue around the house some where. Still the ol' CT puts the ponies down and i run 175/180 jets. But this post isnt a dyno shootout on the 660. He was looking for a dyno for a SLIP-ON, most of these pipe are complete exhausts. Back to subject was about the 700r making weird noises, and clunking when shifting. I was just curious if anyone has heard about this....
Old Sep 26, 2005 | 03:42 AM
  #30
Webopper's Avatar
I'll bet if they spent them big bucks on a Pro Circuit that issue got chitcanned long ago...
