HELP warrior no spark
Old Sep 26, 2005 | 02:37 AM
lfowarrior's Avatar
Default HELP warrior no spark
I have a 2000 warrior that has no spark from the plug.I checked the ohms from my stator coil and one of the plugs is weak 7ohms.Do i need a pulser pickup coil,cdi box or a stator coil
Old Oct 1, 2005 | 06:20 PM
JohnF's Avatar
I have the same problem on an 87 warrior. I have checked all resistance from factory service manual. Everything looks good. It ran great till I washed it a couple weeks ago.
Is there any way to check the CDI box without buying a new one?
Old Oct 1, 2005 | 08:21 PM
UltimateAussie's Avatar
nope the cdi is a closed state sysem with no way to check it if you have a friend that has one or knows someone that has a warrior you might be able to cheack that way
Old Dec 4, 2005 | 01:20 AM
JohnF's Avatar
Well, I finally broke down and bought a new CDI box. Thinking that that was definitely the problem. It still doesn't start. It does have a very weak spark with a brand new plug grounded to the side of the engine case. But, It is not enough spark to start it. The battery is fully charged and I have ohmed out everything per the service manual. The spark plug almost seems like it fires too many times. I am not sure because it is very faint. I do also have a new coil on it.
Does anybody have any suggestions?
Old Dec 4, 2005 | 02:17 AM
Daniel631's Avatar
Disconnect the hot wire from the ignition coil and unplug the CDI. With a DMM on ohms or audible continuity check that wire for continuity to ground. If you get a resistance reading or an audible tone you found the problem.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
