Blaster Weak Spark?
Old Oct 3, 2005 | 12:07 AM
chenz07's Avatar
Default Blaster Weak Spark?
ANY HELP WOULD BE GREATLY APPRECIATED!
My blaster has spark but it is very faint, skinny light blue.IT won't run. I have full compression with new piston and rings and I even sprayed starting fluid into the cyclinder and not even a pop. I tested the coil with a ohm meter just like the manual says and it tested fine. The boot also tested fine. Could it be the stator? Or what else could it be?
Old Oct 3, 2005 | 04:45 PM
Storj's Avatar
Are your plugs gapped right and i would check the stator that might be your problem. Also check for loose conections in your wires. And what plug are you using?
Old Oct 3, 2005 | 09:19 PM
chenz07's Avatar
THe plug is gapped to spec and it is an NGK. I tested the stator with an ohm meter and everything was fine except for the pickup(pulser) coil. In the book it says it should test at above 78 ohms, but mine is at about 30. I have another stator and I checked the pickup coil on that and it tested at 30. Is it possible that they are both bad? I never had either engine running but I was told the one ran.?
Old Oct 4, 2005 | 08:23 PM
Storj's Avatar
maybe you got lied to
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
