WB pipe on a Warrior
Old Oct 5, 2005 | 09:32 PM
ftwflh's Avatar
Default WB pipe on a Warrior
Got one of these off of Ebay for the sons 350 and it was a bear to get lined up ended up shimming the plastic a little and it will still need some heat tape on the plastic.Is there any tricks to lining this up better? And with 7 discs the manual said stock jetting would be ok. It really sounds better and seems to have better responce. Thanks Brad
Old Oct 5, 2005 | 09:59 PM
recon99's Avatar
Did you loosen the headpipe before you installed it? That's something that usually makes lining everything up easier and fit better. You should probably do a spark plug check to make sure that your jetting is still good, no matter what white brothers claim. My HMF wasn't supposed to require rejetting, but I was running so damn lean after I installed it that I needed to get a richer needle to get my midrange right.
Old Oct 5, 2005 | 10:04 PM
ftwflh's Avatar
Yeah I loosened the head pipe(learned that the hard way on a Trailblazer) I plan on a plug check tomorrow in the daylight.Seems to idle and not back fire when I let off from WOT. WB has been real close on what they have told me in the past.But I alway double check.
Old Oct 6, 2005 | 09:45 AM
heatseeker8's Avatar
I had absolutley no problems with my WB slip on..and no rejet needed until you toss the crappy airfilter for a higher flow one.
Old Oct 6, 2005 | 07:12 PM
ftwflh's Avatar
How much will I have to go up with a UNI or K&N filter?The plug is light tan now.
Old Oct 6, 2005 | 09:19 PM
jaggers2e42's Avatar
yeah my wb pipe did not line up worth a crap.where the pipe bolts to the frame there was like a 1 inch gap that i stock a old 1/2 socket to use as a spacer.and it also took alot of forse thanks to a 2x4 and a hammer just to get it slid all the way up.
Old Oct 7, 2005 | 09:32 AM
I got a k&n with a hacked lid and use a 152.5 MJ and dropped one position on the needle..
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
ltzbrad
Sep 25, 2015 05:52 PM
Bernhard
Sep 25, 2015 12:45 PM
greg86hd
Sep 16, 2015 12:32 AM
