88 warrior need to be faster :)
Old Oct 7, 2005 | 04:17 PM
Trevma2's Avatar
Default 88 warrior need to be faster :)
this might sound like a stupid question but could someone help me out on a list of parts to make my warrior a little bit faster? thanx a lot
Old Oct 7, 2005 | 04:42 PM
DavidLT250S's Avatar
new exhauste system, open the air box, play around with the sprokets. is it stock?
Old Oct 7, 2005 | 05:53 PM
2phast4u's Avatar
check out wat i got also is u realli wanna get goin check out the alba 400 stroker kit or fst 400# bigbore stroker kit but if i may ask y do u need it to go faster?
Old Oct 7, 2005 | 08:07 PM
recon99's Avatar
446 stroker warriors are as fast as a piped raptor, but it's expensive and from what i've heard from my shop, they like to blow up frequently. If you are just looking to outrun the 400's, a slip on exhaust, a high comp piston, 5 angle valve job, port polish, and a good cam will do the trick. I've already got the exhaust, and sometime within the next year i'm getting the rest done on my warrior. That's what the shop recommended to me so I can still run pump gas, and keep it reliable for all day trail riding.
Old Oct 7, 2005 | 08:12 PM
recon99's Avatar
Some other great products for the warriors are edelbrock quiksilver carbs and dyna ignitions. The edelbrock, from everything i've heard, is a really worthwhile upgrade for the warrior, gives a 3-5 hp gain all the way through the rpm range, plus no more jets, choke, or problems with hesitation like the stock warrior carb.
Pgbama11
Jan 16, 2016 08:19 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
