RAPTOR 350 .040 over
Old Oct 23, 2005 | 01:05 PM
LOVINMYRAPTOR350's Avatar
Default RAPTOR 350 .040 over
where can you get a new oilcooler kit fore a raptor 350? does it even come in a kit or do you have tio make it, will a stage 1 cam create a overheating problem?
Old Oct 23, 2005 | 01:19 PM
CTATV's Avatar
warrior/wolvy/rap350 definatly dont have any chrome cylinders. I had a sled that was nikasyl coated and couldnt be bored it had to be re-sleeved so there aren instantces where engines cant be bored but thats definatly not one of them. I went with a higher compression wiseco piston and a white brothers high lift cam in my wolverine and it made a big difference. The cam really lets your engine rev out smoother and longer. boring doesnt make a difference unless you do a big bore kit wich is real expensive and not needed on such a new bike. I rode on stock bore from 2001 to 2004 and when i needed a freshened top end I went for the piston/cam. I dont get nearly as many hours on my baby now that im a bit older and in college as opposed to highschool so imagine this will last be for a whiile. by the time this wears out, which shouldnt be for a while, then im going to go with the FST big bore maybe the 446 kit.
Old Oct 23, 2005 | 07:03 PM
recon99's Avatar
The good oil coolers do not come in a kit, you need to buy a oil filter adapter and plate from a yamaha big bear or kodiak 350, and get some kind of oil cooler for a motorcycle or car. I used a tranny cooler for a small car, but you might need something smaller to fit under the rappy's hood. You can get an oil cooler kit for around $65 bucks from a couple places, but they're not worth a $hit, they have a very small cooler, and you have to take off your clutch cover and drill and tap holes in it. If you go to the site yfm350central.com and sign up for a free membership there is a good tutorial there about how to do everything. When I did my oil cooler I spent about $100 and it made a noticable difference on hot days, and hard riding, when the transmission would normally start acting up. I would put the cooler on before I started doing motor mods. You wouldn't necessarily have to put the cooler in for a stage 1 hotcam, but the yfm350 motor can overheat in stock form under certain conditions, and it woud be even more likely to happen with performance mods.
Old Oct 23, 2005 | 08:10 PM
CTracingraptor's Avatar
if your looking for more power out of you raptor350, my advice would be change the cam, and have a pro do a port/polish on your head. and you'll definatley notice a increase in power. My opinion is your first engine upgrade needs to be a port and polish.
Old Oct 23, 2005 | 09:53 PM
  #15
CTATV's Avatar
i never did a port/polish i was always under the impression they do more for a 2 stroke then a 4 stroke. you think i'd notice a difference?
Old Oct 24, 2005 | 12:32 AM
  #16
warriorguy22's Avatar
yes, porting and polishing any atv will give you quite a power gain.
Old Oct 24, 2005 | 02:23 AM
  #17
a ported head is hands down teh best mod you can do for your motor, as long as its done right.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
