Robbing Horsepower??
Old Oct 10, 2005 | 10:37 PM
ZimRaptor's Avatar
Default Robbing Horsepower??
weight does not effect horsepower, unless its directly on the motor
Old Oct 10, 2005 | 10:44 PM
maddog56's Avatar
Not on an engine dyno, but rotating weight both in and outside the machine as well as overall weight will sometimes affect rwhp and just about always drag times.
Old Oct 10, 2005 | 11:44 PM
TJw6981's Avatar
It doesnt rob Horses, just acceleration. A dirty air filter or bad spark plug robs horses [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 11, 2005 | 12:20 AM
JakalWarrior's Avatar
All things being equal, if you cloned yourself and your machine. Then your clone went and took a ****. You both launched the same the same etc... your clone would win [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Oct 11, 2005 | 01:11 AM
  #15
Starky's Avatar
In other words, **** robs horsepower which is what this thread is all about. When you say "horsepower" I believe you are talking about power and speed which are not necessarily the same thing. Two identicle machines with identicle horse power ratings but running one tooth differance in the sprockets are going to produce different results. The same goes for one machine with and without all the pieces/parts that make up reverse. If you remove those parts you have reduced weight, rotating mass and friction. Have you changed the horse power of the machine? No, you just made it easier to get the power from the motor to the ground.
Old Oct 11, 2005 | 01:39 AM
  #16
Bradracer18's Avatar
I agree with you starky.......although need to correct one thing, loosing weight wouldn't make it easier to put the power to the ground, but rather might make the power to the ground more noticable........and will increase acceleration.
Old Oct 11, 2005 | 03:03 AM
  #17
Starky's Avatar
You're right. I'm sure there is a formula for it. Mass times weight over the square root of gravity equals the potential to go fast.
rawbdiggity
Sep 7, 2015 12:05 PM
rawbdiggity
34
Sep 2, 2015 02:16 AM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
robj
Jun 15, 2015 08:45 PM
Ask the Editor
Jun 3, 2015 04:16 PM
