Fuel Leak
Question for you guys...
I have a 2000 Grizzly, orginal owner been very happy with the bike.
I go to fill it up with gas today and gas is streaming out of a tube that appears to come from the bottom of the carburator...?
I thought maybe I just overfilled the tank but the gas keeps coming and coming. If I turn the fuel switch to 'off' then the leak
eventually stops.
I verified the hose from the fuel on/off switch hooks into the carburator, and that looks ok. Seems like the hose that
fuel is coming out of should hook into something but I can't see where it does. Anyway, send me some ideas of you can.
Thanks.
eventually stops.
Thanks.
your float valve is stuck
in the short run, try tapping the bowl with a screwdriver handle
otherwise, pull the carb, remove the bowl and inspet the needle valve connected to the float (blow ome compressed air thru it)
it may be worn out, sticky or have a grain of sand in it
the tube coming off the bottom is the overflow tube,,,,,it just drains to the ground,,,,doesn't go anywhere
had the same problem from a old warrior.rebuit my carb problem solved
by the way i like the name,one thing i've said a few stupid time..lol have the scares to prove it.[img]i/expressions/face-icon-small-happy.gif[/img]
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
