noisey grizzle 660 slowing down
Old Oct 10, 2005 | 02:55 PM
pbm's Avatar
pbm
Default noisey grizzle 660 slowing down
2003 660 grizzle making a lot of clutting and knocking noises when slowing down does anyone know how to remedy this problem.
Old Oct 10, 2005 | 03:00 PM
Grizzly09's Avatar
I own a 2005 660 grizz and i've never had this problem...im not sure wats wrong
good luck with the grizz
Old Oct 10, 2005 | 04:08 PM
THECVMAN's Avatar
You might check your inner cv joints. The symptom of a bad inner cv joint is a vibration or clunking sound during acceleration or deceleration. PM me if you need any pointers.
Danny
"thecvman"
Old Oct 10, 2005 | 06:17 PM
pads's Avatar
Is the noise coming from the front or rear? The rear brakes do make noise because they are braking the drive axles not the wheels. It is a little annoying but seems to work well.
Old Oct 11, 2005 | 01:52 AM
Andy Bassham's Avatar
If its coming from the rear, then the guy above me is right. All Grizzlies make that brake clatter. Annoying, but nothing wrong with it. It just does that crap. I think Rincons do it too because of the brake design, but not sure.
Old Oct 11, 2005 | 03:46 AM
Starky's Avatar
This is a common trait with the Grizzly and something you will get used to. It's most noticable when breaking going down hill.
Old Oct 11, 2005 | 09:18 AM
pbm's Avatar
pbm
i thought this was the rear brakes when it started. but it did not do it when it was new it has about 47 hours on it. after listening to it at frist it sounds like it coming from the back. but when the brakes are applied hard it is really coming from in the transmisson or the clutch. i removed the clutch and inspected it, it seems to be ok. any other sujjestions.
Old Oct 11, 2005 | 09:34 AM
wader's Avatar
i had the same problem couple weeks ago, turned out i had bad bearings in the front end......hope this helps
Old Oct 11, 2005 | 10:38 AM
Starky's Avatar
I'm not positive, but I believe it has to do with the rear drive shaft. It's not the brakes because it does it whether you're braking or not. You just notice it more when you are braking down hill or going over whoop type dumps. Ride around on a motocross track and you will really hear it. If you go on the Grizzly Owners Forum you will see that everyone's bike does it. I have 2 Grizzlies and they have both done it since they were new.
It really is nothing to worry about but you want to be able to recognize it in case you get a different sound that may be a real problem like the barrings.
Old Oct 11, 2005 | 02:16 PM
ridinhigh's Avatar
This may sound stupid but check your heat shield. Mine was making a hell of a noise a month ago and thought it was the belt. I torn it apart about 3 times before my dumba$$ realized it was the heatshield loose. The Yamy dealer said he has had quite a few come in with that same problem.
