Wolverine Engine clatter
Old Oct 18, 2005 | 09:02 PM
BoomSling's Avatar
Default Wolverine Engine clatter
I have an 05 Wolverine. The engine clatters a little at idle. it revs fine. it's coming from the top end. is it just a little bit of valve clatter? i only have about 18hrs on the engine. i don't know anyone else with a wolverine i can compare it to. Is this clattering normal?
thanks,
andy
Old Oct 19, 2005 | 12:15 PM
95wolv's Avatar
The Warrior/Wolverine engine tends to tick a little,if you put a cam with stiffer valve springs in, it will make it louder, in your case, I'm sure it's stock, so just have the valve clearance checked to be safe. An 05 should still be under warranty, see if the dealer will check it for free, or cover it in a scheduled check up.
Old Oct 19, 2005 | 12:23 PM
BoomSling's Avatar
thanks, 95. I'll get it checked when the initial service is due.
andy
Old Oct 19, 2005 | 01:44 PM
CTATV's Avatar
after i did my cam and valve springs mine makes a real tick. I get plenty of confused looks with that, "is that thing broken" look on their face. but yeah for stock 95wolv i agree
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
