What clutch should I buy
Old 10-31-2005 | 03:52 PM
thedieselkid's Avatar
Default What clutch should I buy
My stock clutch is on its last leg, it has maby one or two rides left if I am nice to it. I am not sure which clutch will take my abuse best. I am thiking about barnett, or GYTR. I there are any others please let me know. I want something that will take some hp and not slip, but will still let me go riding all day with no problems. Thanks
Old 10-31-2005 | 04:01 PM
maddog56's Avatar
GYTR is the better part, especially for a modified bike like yours. Barnett isnt bad and if it was all that was around that day I'd put one in, but only with my gytr springs.
Old 10-31-2005 | 05:38 PM
caliraptor's Avatar
GYTR
Old 10-31-2005 | 07:29 PM
Raptor149's Avatar
GYTR
Old 10-31-2005 | 07:33 PM
warwgn's Avatar
hinson makes good strong stuff for the clutch too.
Old 10-31-2005 | 09:37 PM
maddog56's Avatar
Do they make fibres for the 5 spring? I've never seen them that's why I ask.
I'm under the assumption we're just talking a fibre, steel, and spring replacement right? Not a new basket and pressure plate, even though the GYTR parts are identical to the Hinson ones for the 5 spring.
Old 11-01-2005 | 07:21 PM
AustinONeal's Avatar
i just ordered a hinson 6 spring system with a billet basket i was told it woud be good for my setup
(should be in tomorrow bob)
Old 11-01-2005 | 10:39 PM
DriverDoyle's Avatar
Even though i run a barnett dirt digger system in mine i would have to agree with my fellow blacksheep member Austin Oneal you cant go wrong with a hanson system.
Old 11-01-2005 | 11:03 PM
maddog56's Avatar
6 disc hinson system: 800 bucks +
GYTR replacement plates with springs: 80 bucks.
Now if you were considering a new billet clutch basket and pressure plate for your stock setup (about 500 bucks) then I might consider the 6 spring as an upgrade. Or if you just have the money lying around and would like something better. But there is a big difference between a replacement clutch set and replacing your whole clutch...
Old 11-02-2005 | 06:11 PM
warwgn's Avatar
your right maddog I was talking about the whole clutch, I thought that was what he wanted.
Quick Reply: What clutch should I buy
