CT raptor 660
Old Nov 4, 2005 | 01:19 AM
Seibert51's Avatar
Default CT raptor 660
I just orderd the full CT pipe and K@N with jets and all that and i was wondering if the jetting will be that hard for a person who has never been inside the carbs. Ive put on pipes and all that but i have never been inside the carbs. I have read hundreds of posts and articles on jetting and i think i will be able to do it but i dont want to take apart my raptor and just get lost. Any advice will be awsome.
Im really sorry im posting another post about jetting but i need to know this before i open up my raptor.
Any thing yall reply would be awsome any tips or anything
Luke
Old Nov 4, 2005 | 02:23 AM
maddog56's Avatar
The pipe comes with jetting instructions, I would recommend 160/165, aftermarket needle on 3rd clip, 25 pilots and 1.5 turns out.
Old Nov 4, 2005 | 11:22 AM
Seibert51's Avatar
But it is pretty easy to do all that.
Old Nov 4, 2005 | 11:24 AM
Seibert51's Avatar
I mean is it pretty easy to do that?
Old Nov 4, 2005 | 11:45 AM
MasterRaptor's Avatar
The thing you have to watch for is 1: stripping the screw heads on the bowls, and 2: not securing the carbs properly in the intake boots when re installing. 3: Don't mess up the order of the spacers on the needles.
1: Before you try to break the screws loose on the carb, give it your screw driver a hard tap with a hammer. This usually does the trick. Make sure you have a good quality philips.
2: Make sure the carbs are completely seated in the boots before you tighten the clamps. Push the carbs into the boots as hard as you can. Tighten the intake boots before you tighten the air box boots. If they are not seated, they will fall out and the bike will die instantly.
3:When pulling the needles out, becareful not to dump the spacers on the floor before you can see how they went on the needles.
Other than that it is easy. Pull the front plastic and tank, then pull the carbs.
CT is a bad *** pipe. Sometimes they don't fit very well, but they wake your bike up.
1LeSSRaptor's Avatar
What's up Siebert,
The instructions that come with the jets are very understandable. I was worried the first time I did it, but after digging in, it's a breeze. I can do it in my sleep. The hardest part is take off the plastics to get to the carbs which is not that hard either, just takes time. Just remember that there are some delicate parts in there such as the floats, diaphrams, and springs that you need to make sure that you aren't rough with or lose. If you need any help, there's always a lot of info. to get you through the process.
Also, I sent you a pm! You've got mail.
Old Nov 4, 2005 | 11:53 AM
Air's Avatar
Air
To stop from stripping the screws get a small tube of Valve lapping compound an put a small amount on the end of the screwdriver.It also helps take out stripped screws
When you get a screw out of the carb run over to a hardware store and get 8 stainless allens to replace them.
Old Nov 4, 2005 | 12:01 PM
Seibert51's Avatar
Thank yall for all the help, by the way i never got ur PM
Old Nov 4, 2005 | 01:44 PM
1111's Avatar
hey every body 'just picked up a rapptor 50 for my just turned seven year old boy and what a good time hes haveing no hassels and problems {dad got him self a 660] just wanted other parents to know make your kid wait till he legal it worth it he waited and waited then took to it like a duck takes to water . first day out at a local ride spot were we live and boy just went for running little jumps and roosting dirt never even hade to use the throttle screw or tether line what a great ride for new riders at 7 years so young any ways hi to every body like all the post and my 66o rapptor is still stock i know i1ll get on the hop up parts at soem point any good riding to every body out there
Old Nov 4, 2005 | 02:12 PM
congrats on you new purchase and introduction to family fun my kids have been riding since 2 years old with tethers and all they took to is like flys to **** even then yeah you got to get the hop ups to really have fun theres alot of stuf you can do your kids 50 as well enjoy and be safe now my brain hurts
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
