Carb set up ?
Old Nov 4, 2005 | 09:23 AM
claw1's Avatar
Default Carb set up ?
Ok now that that my warrior is running I need some tuning help. The motor has a White bros. cam , 10.5 piston std. bore and a cobra pipe. The guy I got it from had someone else do everything so don't know how it was set up. My carb is stock. There is a 14 tooth sprocket up front. It is lazy from low to mid range unless you dump the clutch. From what I see on other posts I belive I'm lean. Is this correct? Anyone have imput to use to as starting point? Thanks
Old Nov 4, 2005 | 11:12 PM
maddog56's Avatar
Judging from the white bros cam and cobra pipe, I'm guessing warrior right?
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
