filter retention for raptor?
Old Nov 9, 2005 | 09:17 PM
Dowery660's Avatar
Default filter retention for raptor?
Who makes a filter retention accessory to work with the outerwears airbox cover? whats the price and where could I find one? Or what have others done to make one?
Old Nov 9, 2005 | 10:48 PM
maddog56's Avatar
I thought the outerwears lid kept the stock filter in place...
Old Nov 9, 2005 | 11:25 PM
Dowery660's Avatar
The instruction sheet states at the very top of the instructions
"YOU MUST HAVE AN AFTERMARKET AIRBOX MODIFICATION THAT HOLDS THE AIR FILTER IN PLACE TO USE THIS KIT!!!!!!"
I don't know anyone who has used an outerwear so I figured something else is needed to keep the the filter in place to avoid ruining the outerwear and allowing water and debris to get in. If it is durable I have no problem with running it like you said, but none the less I'm interested to see what options there are.
Old Nov 9, 2005 | 11:44 PM
Turtler's Avatar
Dowery,
The stock retention system blows, so does the stock filter. Get yourself a Pro Design manifold, o-ring sealed and bolted to the airbox and a uni or K&N filter. Then you have a good filter attachment to the airbox.
Old Nov 10, 2005 | 01:31 AM
caliraptor's Avatar
I think hes talking about the outerwears airbox cover(the one that velcros ontop of the box), not the lid with the outerwears in the middle.
Get yourself a pro-design intake like someone else said.
Old Nov 10, 2005 | 01:59 AM
maddog56's Avatar
Gotcha, didnt know there was such a thing. All I've ever seen is the lid.
Pro-design if you're keeping the airbox, L&A adaptor if you're not.
Old Nov 10, 2005 | 04:03 AM
Dowery660's Avatar
Yup, velcro it is. I'm the polar opposite of Maddog 'cause I did not realize there was a different lid. Anyways, I do plan on changing the intake at some point, but for now or at least until spring, I am gonna keep the box hooked up because of weather.
Old Nov 10, 2005 | 12:25 PM
warwgn's Avatar
drill a small hole through the top of the filter flange and the air box, then put a bolt with a lock washer and nut on it and tighten it up. That will hold the filter in place and keep a good seal also. I still have a little of my stock air box left, I made a (G-string out of a pair of shorts) to compare how much I cut away from the stock box and I bolted it up like above states and it works perfect. I live and ride in the desert so I just threw an outer wear on the filter and I'm good, but I never see mud or water where I ride, just dust. But a bolt will fix you up for cheap untill you get a new intake.
Old Nov 10, 2005 | 05:32 PM
Dowery660's Avatar
Warwagon, you got my vote. That's so simple I would have never thought of it. Thanx for the input. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 10, 2005 | 06:54 PM
caliraptor's Avatar
I used a self tapping screw on the stock filter. I still dont think that the gasket with that K&N drop in is good enough to prevent any dust from getting into the engine, but it is a cheap way to do it. When you get the $, buy the pro design intake.
