Engine Ice
Old Nov 11, 2005 | 08:55 PM
BubbaGumpShrimpShack's Avatar
Default Engine Ice
does this stuff really work. how many degrees does it keep your bike cooler.
Old Nov 11, 2005 | 09:56 PM
YFZ200's Avatar
Default Engine Ice
I don't know what you are talking about?
Old Nov 11, 2005 | 10:35 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Default Engine Ice
Ya it works GREAT......I don't know the chill factor but if i lived/rode in a WARM climate, this is what i'd use......[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 12, 2005 | 12:26 AM
Default Engine Ice
coolant for your radiator
Old Nov 12, 2005 | 12:53 AM
Starky's Avatar
Default Engine Ice
Yes Bubba, it works. But you have to figure out what is causing your bike to overheat if it's actually overheating or if it's an electrical problem.
Old Nov 12, 2005 | 12:55 AM
DuneRider650's Avatar
I ride a little here and there......
Default Engine Ice
i couldnt really tell any diff but its supposed to work....
Default Engine Ice
all i know is that the light comes on when im going slow for awhile. the light shouldnt come on if everything is working properly
Old Nov 12, 2005 | 11:57 AM
warriorboy22's Avatar
Default Engine Ice
u shouldnt try to avoid the problem by making everything run cooler try to figure out whats making it over heat
Old Nov 12, 2005 | 02:10 PM
HooPharted's Avatar
Default Engine Ice
it does work,,,i flushed the system twice,added blue ice,and it definatly made the engine run alot smoother,,,im telling you i could tell the diferance in how the engine ran
Old Nov 12, 2005 | 06:38 PM
quadbart's Avatar
Default Engine Ice
Engine ice........does it work, yes.
Does it work better than regular antifreeze? ah, not really.
There are 2 types of antifreeze.
Propylene Glycol Base Engine Coolant and ethylene glycol type engine coolant.
Ethylene glycol type coolant is the older and very toxic type of engine coolant.
Engine Ice is the newer Propylene Glycol thats less toxic and cools better than the older type of antifreeze.
The ONLY difference between it and a gallon of antifreeze of the same chemical composition is that Engine ice costs twice as much and is already premixed with water.
Engine ice costs about $19.00 a gallon and you use it straight.
Propylene Glycol based Antifreeze costs $8.00 a gallon and after you mix it you have 2 gallons.
Look for "Propylene Glycol" on the bottle of antifreeze and your basically buying twice as much engine ice at half the cost.
I have used both Propylene Glycol antifreeze and engine ice in both my highly modded Raptor and my Raptor with the gsxr 1000 motor in it. They both ran at the same temperature.
If you read the info on both, you will see that both have IDENTICLE properties. They both protect to 250 degrees F.
I used to use engine ice, I now use Propylene Glycol based antifreeze. Theres no differance as far as im concerned.
