raptor rod ?
Old Nov 15, 2005 | 04:49 AM
slidesquad's Avatar
Default raptor rod ?
hey i had a question i was thinking about getting the boondockers nitrous kit and running a 20 hp shot butt will the raptor's rod hold up to that if so for how long?
Old Nov 15, 2005 | 06:05 AM
BayAreaYFZ's Avatar
Probably about 40ft [img]i/expressions/face-icon-small-wink.gif[/img]
Old Nov 15, 2005 | 06:32 AM
slidesquad's Avatar
have you even drove your 450 for more then that??? yours hasent even touched the dirt[img]i/expressions/face-icon-small-disgusted.gif[/img]
lumpys raptor is running good right?
Old Nov 15, 2005 | 11:22 AM
maddog56's Avatar
I thought the boondockers maxxes out at a 20 shot with included hardware, I'd stick to a 15. And if you're running that on a stock motor then it should hold up, just make sure you're not leaning it out.
Old Nov 15, 2005 | 11:56 AM
garyc660R's Avatar
Any time you add more pressure to the rod the potential is there for failure....for the Raptor AND YFZ. Yamaha needs to get rid of some of the bean counters and hire more engineers!
Old Nov 29, 2005 | 03:46 AM
slidesquad's Avatar
what is the best rod to buy and do i need to buy a crank allso? i see the hot rod crank and rod set up am i able to just buy a rod and whats the lightest yet strong rod?
Old Nov 29, 2005 | 04:25 AM
maddog56's Avatar
Still havent seen one better than barker's, but falicon may have a knife rod or something similar for the rap.
Old Nov 29, 2005 | 06:57 AM
slidesquad's Avatar
do you have a website for barker or the falcon?
Old Nov 29, 2005 | 07:04 AM
slidesquad's Avatar
and what is the best cam i should buy i dont want to re do the head but want max hp out of a stage one cam
Old Nov 29, 2005 | 11:29 AM
maddog56's Avatar
barkersbars.com
faliconcranks.com
As far as cam goes that is best purchased in conjuction with your porting design. If you dont have/arent getting a port job then I'd either stick with the stage 1 or up to a stage 2 and new valve springs. You dont really want to get very aggressive with the cam without a higher compression piston to offset it.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
