Bruin cutting out
Old Nov 26, 2005 | 01:37 PM
Blueridge1011's Avatar
Default Bruin cutting out
Old Nov 26, 2005 | 01:41 PM
Bruin cutting out
Starts and runs great, and all of a sudden, while driving, it goes dead, as if there is no spark. After sitting for 3-4 minutes it cranks and goes.
I have a bad battery i will be replacing. Could this have anything to do with it, or is there another problem?
Old Nov 26, 2005 | 02:01 PM
yfx250's Avatar
check your fuses because my beartracker did that when the fuses were going up in it and then it just died and when i got new fuses then it ran fine.
Old Nov 26, 2005 | 05:52 PM
hondabuster's Avatar
Do all of the lights go dead at that point too? If you loose all volts from the battery, the motor will kill. But its unusual for the battery to drop out, and then come back, they usually just die and never come back.
Bring along a spare spark plug, and next time it dies, unhook the spark plug wire, put the new one in, and hold it against the engine...and crank it over, if you have spark, then youve probably got a fuel problem.
Are you low on gas? If you open the drain at the float bowl when it dies...does fuel come out?
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Elkaholic
Sep 6, 2015 02:44 PM
