1996 Yamaha Timberwolf HELP!!!
Old Dec 13, 2005 | 12:37 PM
Tyayo420batavia's Avatar
Default 1996 Yamaha Timberwolf HELP!!!
Hey, i recently baught a 1996 yamaha timberwolf 250 2x4 used from someone in town for $800, for something to beat around in in the winter in ny it runs perfectly, but about 2 days ago i lost my keys. I need to know what i can do to fix this, i found an ignition switch at a local dealer in town but its 59.99 for the part with the key and 2 keys, i have a 2004 bombardier baja 650, and a polaris sportsman 700 so i really dont want to sicnk money in it and was wondering if i could hook up a toogle switch for on off rather then the key switch and if so, how to configure the wires for it. If anyone can help me i would appreciate it alot, if the only was around this is to buy the new switch i guess i will but i ont want to. Or if i can unplug oneside of the switch would that work? And how many plugs g into the switch on the wheeler itself? 2 or 3? im asking cuz my wheeler is at my buddies abt 10 miles away and its a little hard to go look right now myself, thanks alot!
Old Apr 19, 2006 | 05:11 PM
STAJ36's Avatar
This info is probably too late to be of any help. But yes, you can bypass the ignition switch. What you will need is a manual that shows the wiring schematic in order to know what wire or wires to connect to a toggle switch. And you may need more than 1 toggle switch to make everything function like it should.
Old Dec 11, 2006 | 03:29 AM
ta305tpi's Avatar
ahh all you need to do is drill out the key switch. once you get to the bottom you can turn what is left of the switch with a screwdriver
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
chewy78
Sep 8, 2015 10:37 AM
