oil burning
Old Dec 15, 2005 | 07:56 PM
raptorider660's Avatar
Default oil burning
what could signs be that ur burning oil and wat could it
Old Dec 15, 2005 | 08:04 PM
counterpunch's Avatar
Default oil burning
i think it would be giving off blue smoke?
Old Dec 15, 2005 | 08:08 PM
DSNUT's Avatar
Default oil burning
I didn't fully understand your question. Are you asking what the symptoms caused by oil burning would be?
Oil level dropping
Valve stem seals will trickle oil into the cylinder when idling and coasting so you get a puff of blue smoke when you hit the gas but it should clear up under load.
Rings will usually give you steady blue smoke in your exhaust that increases with throttle application. The bigger the leak, the more blue smoke.
Oil only burns blue. Black smoke is a rich mixture, white smoke is usually coolant getting into the combustion chamber.
Keep a close eye on your oil level. Quite a bit of blue smoke means quite a bit of oil consumption.
Old Dec 15, 2005 | 08:24 PM
Default oil burning
at first when i start my raptor it smokes alot of white but only wen i start it then after it warms up really good it doesnt do it any more so i was thing maybe it burnin oil
Old Dec 15, 2005 | 08:28 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default oil burning
thats just because its running rich for a moment
it will be pronounced when the choke is on
Old Dec 15, 2005 | 08:50 PM
Default oil burning
ohhh ok thanks but my friend told me to hit the gas all the way and if it pops/like bog a bit its that its burning oil and i did it and it like boged /poped really quick twice
Old Dec 15, 2005 | 08:55 PM
Bing's Avatar
Super Quad Patrol
Default oil burning
sounds like carburation to me
Old Dec 15, 2005 | 09:15 PM
DSNUT's Avatar
Default oil burning
That is because it is still cold. Does it pop and bog after it quits smoking?
Old Dec 15, 2005 | 09:45 PM
Default oil burning
idk i have to check let u know tomorow
Old Dec 15, 2005 | 09:54 PM
DSNUT's Avatar
Default oil burning
It emits light smoke when it is cold with the choke on, as it warms up you turn the choke off and the smoke clears up. Your friend says when you bury the throttle while it is cold and choked that if it pops and bogs it is burning oil!!![img]i/expressions/face-icon-small-disgusted.gif[/img]
Unbelievable! He doesn't happen to be trying to buy it from you does he?
