Raptor One-way question
Old Dec 16, 2005 | 06:27 PM
maddog56's Avatar
Default Raptor One-way question
Since all of America is out of L&A's for another month or two I'm curious what type of damage is done to the machine if run with a bad oneway. Mine is intermittent, it usually works but every once in a while she starts spinning. If I were to simply pull/bump start it every time instead of taxing the dying oneway would that help? Even if the bike is only started this way, am I still subject to the horror stories I hear about busted off bolts and torn apart bottom ends?
Old Dec 16, 2005 | 08:18 PM
sixsixT's Avatar
When you run your engine with a bad part bad things can happen. But if you removed the flywheel checked the bolts and cleaned out the metal, I would think you'd be safe for a little while.
Old Dec 19, 2005 | 09:27 AM
heatseeker8's Avatar
your working on your Raptor again?
cmon man..every thought of painting it like...maybe LEMON yellow?..lol..if you need a ride for TUT you can ride my warrior...hehehehehe
Old Dec 19, 2005 | 02:36 PM
fordplay2's Avatar
All i know is when my first one way went out there was metal every where. I replaced it with another stock one not knowing about L A one ways. And now 7 months later it is going out again. I try not to ride it too much right now because i dond want to hurt something else.
Old Dec 19, 2005 | 02:54 PM
bigjimmy636's Avatar
ckeck out raptortranny.com they have a temporary fix for you on there that uses an o-ring, just something to check out.
Old Dec 19, 2005 | 03:05 PM
fordplay2's Avatar
Yeah i know about that fix. I would but im tired of breaking in to the motor. I am just going to save up some money to get the L & As. I appreatiate the advice though.
Firefighter400
Oct 8, 2022 06:38 PM
Aug 21, 2015 01:23 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
yambam13
Jul 4, 2015 01:49 PM
