kodiak won't start
Old Dec 16, 2005 | 10:14 PM
willywonka's Avatar
Default kodiak won't start
i have a 2003 kodiak 450 and it quit on me the other day i thought it might be my coil but i don't have any power going to the coil. i have a Multimeter but it says in the manual to test the stator with 100x homs but my meter just has 200 2000 20k 200k 2000k. can anybody tell me if i need a different Multimeter or what setting to use or any ideas to get my bike going . thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 16, 2005 | 11:17 PM
IdahoVinnie's Avatar
Example: Let's say that you want to test a 12 volt battery for proper volts. Your meter has sacles of 10 volts, 20 volts, and 100 volts. If you used the 10 volt scale, your reading would exceed the scale. You could use either the 20 or 100 scale, but on the 100 scale, the reading woud be too difficult to be very exact. Therefore, the best scale to use would be the 20 volt scale.
The same principal holds true for an ohm meter. (It merely measures the resistance in the circuit.) If the desired readings are approximately 100 ohms, then use the scale that has a maximun reading that is higher than the 100 ohms.
Is that clearer now, or did I confuse you more?
BTW, I am confused as to the meaning of the "x" in your statement of "100x".
Old Dec 17, 2005 | 12:04 PM
willywonka's Avatar
thanks it is a little clearer to me now. as for the 100 x that is what it says to set the metre to in my repair manual . my friends multimeter has it in his so i have it figured out now, thanks for the help .
Mattius
Jul 11, 2015 10:44 PM
TLC
Jul 1, 2015 08:29 AM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
1000gade
May 27, 2015 12:37 PM
