Sprokets
Old Dec 22, 2005 | 05:56 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Default Sprokets
I am interested in swapping out the stock sprokets in my 2006 Raptor 350 but, I'm not sure if I need sprokets with more or less teeth to make it faster, also if I swap out the sprokets will I need to change the gear ratio?
Old Dec 22, 2005 | 06:43 PM
warriorguy22's Avatar
Default Sprokets
Whoa, whoa, whoa... back the truck up. Are you sure you're not confusing sprockets with something else? Changing the sprockets is changing the gear ratio. What do you define as "faster", more top speed or more acceleration? Going up teeth on the front gives you more top speed where as going down gives you more accel. Vice Versa for the rear.
Old Dec 22, 2005 | 06:49 PM
warriorboy22's Avatar
Default Sprokets
i wouldnt mess with the gear ratio even though i was thining of droping a tooth in the front sprocket.
Old Dec 22, 2005 | 08:40 PM
420rappy's Avatar
Default Sprokets
i wen't to a 12 t in the front, and it gained low end power and lost a little on the top end .that is what i needed for the trails i ride in. so you might want to figure out what you want, low end or top end.
Old Dec 22, 2005 | 09:27 PM
ATVrider89's Avatar
Default Sprokets
To answer warrior guys question I fefine more speed as the machine being able to actualy go faster.
Old Dec 22, 2005 | 09:47 PM
420rappy's Avatar
Default Sprokets
well if you want it to "go faster" from 0, go down a tooth in the front. if you want it "go faster" meaning you want it to do more mph gain a tooth in the front. reverse it for the rear sprocket
Old Dec 22, 2005 | 10:58 PM
Default Sprokets
does changin the sprockets change the length of the gears
also is it better to drop a tooth in the front or add a tooth on the back?
Old Dec 22, 2005 | 11:05 PM
Default Sprokets
Changing one tooth in the front is equal to changing 2.75 teeth in the rear.
Old Dec 23, 2005 | 07:09 PM
420rappy's Avatar
Default Sprokets
i think it would be better to do the front.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Motordude0616
Apr 4, 2001 10:20 PM
MIA400EX
Mar 27, 2001 10:24 AM
honda205X
Mar 24, 2001 01:36 PM
dondiesel8
Jun 15, 2000 04:19 PM
