Compression on a raptor???
Old Dec 24, 2005 | 09:28 AM
raptorracing's Avatar
Default Compression on a raptor???
Does anyone know what the compression would be with a 12to 1 piston in it? Also when the decompression is working how much compression will it let off?When the decompression pin is opening the valve what is the clearance in thousandth?That way i can see it the rocker arm is needs to be replaced.If it is bad how does one go about getting it welded and harded?
New guy
Old Dec 24, 2005 | 12:30 PM
CTracingraptor's Avatar
most guy on hi comp iston have the decomp pin removed and they have a little blue button you press to release the pressure in the cylinder for easier starting. you can remove the decomp pin and be fine without, its jsut a little harder on your starter, and battery.
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
