Raptor 700 speed limiter
Old Dec 27, 2005 | 02:51 PM
YFZRyderMace's Avatar
Default Raptor 700 speed limiter
Does anyone know how to get rid of the speed limiter? Mace
Old Dec 27, 2005 | 05:41 PM
Wandell's Avatar
I would imagine it's electronic on the new 700 which would mean the computer needs to be reprogramed.
Old Dec 27, 2005 | 06:56 PM
speedrocks's Avatar
Dont cha just make sure the screw is all the way out on the right handle bar.....thats what the owners maanual says
Old Dec 27, 2005 | 07:35 PM
maddog56's Avatar
To actually answer your question with some understanding of the situation, no I dont believe anyone's found a way around it yet.
Old Dec 27, 2005 | 07:41 PM
Well what is the main reason they put the speed limiter on the 700?
Old Dec 27, 2005 | 08:16 PM
bigluke2004's Avatar
if i'm correct ,there is only a throttle restricter ,i don't think there are any limiter/restricters on the engine side of things i kept the restricter in mine to break the engine in at low to mid revs now it's taken out the thing screams it's rapid
Old Dec 27, 2005 | 08:33 PM
maddog56's Avatar
The screw in the throttle housing is present on just about every atv, and is not the item being discussed here. Apparently there is a functioning hardware speed restrictor in the bike that functions in 4th and 5th gears.
Old Dec 27, 2005 | 08:48 PM
Yeah Maddog is right all atvs has throttle restrictors. But there is something else that is holding the motor back in only 5th and maybe 4th gear. Mace
Old Dec 27, 2005 | 08:57 PM
o.k this is first i've heard of a hardware restrictor i'll go test mine out in 4th and 5th tomorrow properly and have a look
Old Dec 27, 2005 | 09:04 PM
ok tell us about your results and HP and Torge numbers too. But everyone is saying that your RPMS will stop at 6500 in 5th instead of the 9000 through the other gears.
