Banshee Rear Bearing Carrier!!!
Is it possible to put a grease fitting in the rear bearing carrier of my banshee, had to replace my bearings from the factory because there was no grease in them. And I saw a aftermarket carrier on the internet, and it had a grease fitting on it, so i was wondering if it was possible.
I seen where it was done to a blaster.They just drilled and tapped a small hole in the carrier and installed an grease aligmite(I know that's probably spelled wrong,but you get the idea).I've never tried it though.So I can't say for sure whether it's a good idea or not.
I seen you're from Arkansas.I live in Paragould,Ar.
07-07-2015 11:00 PM
