my raptor 700 break-in almost over
Old Dec 29, 2005 | 06:46 PM
bigluke2004's Avatar
Default my raptor 700 break-in almost over
hi i've ridden my raptor now since i've got it for about 8 hours ,shall i change the oil on it now,if so what oil shall i use , shall i use fully synthetic 4 stroke, which brand is best? also what is that stuff underneath the left front fender and what do i replace it with when it gets to low? again what brand etc works best? also how often should replace oil filters and how often should i replace clean air filter, would appreciate your ideas guys
Old Dec 29, 2005 | 09:02 PM
RDZ350's Avatar
Not for sure.What does Yamaha recommend?
Old Dec 29, 2005 | 11:06 PM
BlazinOrange700's Avatar
Yamaha will of coarse recommend Yamalube. I hate that stuff.
Run some Castrol ATV oil in it.
The stuff under the front left fender would be the coolant bottle, when it gets low, replace it with Coolant(make sure to mix with some water as well), make sure that Coolant or just drain the entire system and put some Engine Ice or Evans Coolant in it, these will make the motor run a lot cooler leading to better performance.
As far as oil filters go, replace those about everytime you change the oil, may not need to replace it this often, it's just nice to know you wont have any troubles with it, not like they cost a lot of money in the first place.
Air filter, clean that about every other ride. After it starts getting old/raggy, replace it with an aftermarket one or another OEM filter.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
