is this true
Old Jan 1, 2006 | 08:23 AM
fastblaster00's Avatar
Default is this true
ya i was the one who posted the ?. i want to do a 3mm stroker crank and a 240 kit..... id go for a 6mm if i knew a place to have the block machined. the 3mm fits in with no machining.
o and the 3mm stroker crank adds a lil more than 10ccs
Old Jan 1, 2006 | 03:59 PM
midnite's Avatar
Originally posted by: MDS2106
Well I was there at Sicily Island when that little blaster was running,it only got to make a few passes then it broke down.Its going to take alot more than just pipes and removing the air box lid to beat that little blaster.By the way the blaster won that race.
What I mean is a typical modded blaster {stroker crank, pipe, larger carb, cr250 reed cages} will get beat by a piped banshee. The blaster on that video is impressive. But, it has alot more done to it than the typical modded blaster. Did it run on alcohol? Did it even have a blaster motor in it? Did it run nitrous oxide? Again it's impressive, but may be the only blaster in the world that runs like that.
Old Jan 1, 2006 | 04:16 PM
DavidLT250S's Avatar
in that video what happened to the green banshee? it looks like it went like 10 feet and broke?
Old Jan 1, 2006 | 06:48 PM
  #15
$20 says at least 2 of the shees were on alky. watch the videos from
http://www.cpcustoms.com/blaster_vids.htm and ull see what 6mm stroker crank can really do
Old Jan 1, 2006 | 07:03 PM
  #16
Fastblasterboy's Avatar
I was the one who said a 6mm stroker blaster can eat a modded banshee and a sparks 450r.
http://www.cpcustoms.com/blaster_vids.htm <- copy and past that.... theres my proof.
Old Jan 1, 2006 | 07:05 PM
  #17
LoL watch the vid where the blaster races the DRAG 416ex..... HAHAHAHAHAHAHA he got smoked.
shimanok2
Jan 29, 2016 07:37 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
