Hotcam stage 1 or 2?
Old Jan 2, 2006 | 02:14 AM
89warrior's Avatar
Default Hotcam stage 1 or 2?
Hello I have a 89 warrior that I am rebuilding. I was wondering if I should throw in a HC and if so witch stage? I only do a lot of trail riding and jumping. So far I have:
Wiseco 10.5:1 std bore
EBC dirt racer clutch
Cobra megaphone exhaust
brand new cylinder head all stock
Brand new cylinder
2002 stock carb
raptor 660 R rear shock
2002 warrior front shocks
2002 black plastic
Anyway's, will putting a cam in it even be worth it. The warrior is pretty much all stock. Let me know what you guys think.
Old Jan 2, 2006 | 11:19 AM
DriverDoyle's Avatar
Yeah the cam is worth it... They give you bottom to mid range pull... But If you get a hot cam they only make a stage 1.... for a warrior...
Old Jan 2, 2006 | 03:50 PM
89warrior's Avatar
OK thanks, after installing the hot cam is the difference noticeable? Will the timing need to be changed?
Old Jan 2, 2006 | 09:56 PM
No you do not have to change your timing.....
And yes... You will have more botton end pull with the stage 1 hot cam...
Old Jan 2, 2006 | 11:07 PM
89warrior's Avatar
thanks for the help!
Old Jan 3, 2006 | 01:32 AM
89warrior's Avatar
does a new bearing come with the hot cam? or can I just take the old one off the stock cam and put on the new cam?
Old Jan 3, 2006 | 08:18 AM
Mine did not come with new bearings.. But i put new in when i got it... I would get new bearings there not that high....I would not put the new cam in without new bearings...
Old Jan 3, 2006 | 10:49 PM
89warrior's Avatar
How do you get the old cam bering out of the back of the head? Then how do you get it back in?
Old Jan 4, 2006 | 01:48 AM
What you need to do is get a book... Its been about 6 months sence i did it... Your best bet is to go to your yamaha shop and spend $30.00 on the book so you can have all the speces
Old Jan 4, 2006 | 07:59 PM
89warrior's Avatar
Dude i have a book!
