Valve job
Old Jan 4, 2006 | 03:00 PM
carguy07's Avatar
Default Valve job
what's a valve job? and what will it do for me?
Old Jan 4, 2006 | 08:51 PM
Daniel631's Avatar
Default Valve job
It usually means a lash adjustment. The valves get tight over time and need to be adjusted back to spec. Loose valves tick, and tight valves make starting the bike difficult sometimes.
If you hear a loud ticking sound coming from the head that gets faster and louder with throttle, your valves are loose. If your bike has spark, good fuel and a clean filter but won't start the intake valve most often is tight.
Old Jan 4, 2006 | 11:21 PM
Doctorturbo's Avatar
GOT BOOST!
Default Valve job
Around my neck of the woods a valve job is when you grind the valve and seat to a perfect finish and match.
If you get a 3 angle job it will help the flow because you can set the surface mating size. In theory, the narrower the mating surface the more flow you will get. The valve will disapate less heat though.
Maybe a lot, maybe nothing.
Old Jan 5, 2006 | 01:00 AM
Daniel631's Avatar
Default Valve job
I/we where I come from call that "cutting seats". Usually replace the valves depending on the wear and if they are coated or not. Do a 3 angle cut on the seats and lap them if neccessary.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
