FMF COMBO=HAPPY
Old 01-18-2006 | 12:28 AM
DesertViper's Avatar
Default FMF COMBO=HAPPY
Adjust your fuel mixture screws and it will take care of the too lean idle setting. And check your plug.
DesertViper
Old 01-19-2006 | 11:21 PM
dragraceraptor's Avatar
This weekend or the next one, i'llhange the jets of my raptor. I'll put the size 148 and 146. Thats what it says on the dynojet kit and i'll let you know how it works.
Joel
Old 01-19-2006 | 11:49 PM
firebirdjosh's Avatar
Leaning out the engine risks serious damage, jet up or don't ride it. Red hot means there's a problem.
Old 01-19-2006 | 11:59 PM
1STXTIMERX's Avatar
the Dyno Jet kit usually tells you which jet you should start with.
Not sure where you bought it.. but if it came from ebay check this website out
http://www.dynojet.com/jetkits.php
There are frauds floating around...
  #15
Old 01-24-2006 | 10:12 PM
Hey guys, I just put back bigger jets(146,148) and its running fine,except the front headers glows red again[img]i/expressions/face-icon-small-sad.gif[/img] So what do you guys say bout that?
any help would be very appreciated thanx
Joel
  #16
Old 01-24-2006 | 10:13 PM
By the way,it glowing red only at idle and slow speed thanx
  #17
Old 01-24-2006 | 10:58 PM
caliraptor's Avatar
Ive got a fmf header as well and it glows at idle. Make sure your air screws are 3 turns out.
  #18
Old 01-24-2006 | 11:02 PM
yeah I did the airscrew. But are you sure its normal to glow at idle? because it looks weird? maybe im wrong
Joel
  #19
Old 01-25-2006 | 12:55 AM
caliraptor's Avatar
Try going with 25 pilots then
  #20
Old 01-28-2006 | 03:56 PM
k im doing this tomorow....haha i just realize something else...when im driving, if I let the gear on the top rpm and then shift it, it will bog a little and after it seems not that strong. Any advice?
thanx
joel
Quick Reply: FMF COMBO=HAPPY
