Different cam options
Old Jan 16, 2006 | 12:47 AM
thedieselkid's Avatar
Default Different cam options
Right now I have a stage 2 hot cam, and I was wondering if there was anything that is more aggresive out there right now.
Old Jan 16, 2006 | 01:09 AM
UBETRUN's Avatar
X-4, X-14, and Craycraft's cam are all more aggressive than a Stage 2.
Old Jan 16, 2006 | 03:43 AM
maddog56's Avatar
Not to mention about 3 more cams from Megacycle and 4 or so cams from Web.
Old Jan 16, 2006 | 08:34 AM
UBETRUN's Avatar
Mention them, what are the model numbers?
Old Jan 16, 2006 | 09:52 AM
maddog56's Avatar
The x2 and x11 have similar/slightly more aggressive profiles compared to the stage 2. The x3 is one you left out as well, which is certainly a step up from the stage 2 HC.
As for webs, the 736 and 685 cams are more so than the stage 2, and the 696 is a tad above as well. Guess I was one short there.
Old Jan 16, 2006 | 05:56 PM
fastquad02blaster's Avatar
Do the cams you all mentioned decrease your low end power very much? Is it enough to make you think twice about all the high end power you do gain? I'm thinking of buying a raptor and am picking up some info.
Old Jan 16, 2006 | 10:40 PM
CTracingraptor's Avatar
once you go bigger than the stage 2 cam, the lose of your bottom end is significant.
although craycraft drag cam has more bottom then stallion's stage 2 cam(IMO ive riden both)
Old Jan 17, 2006 | 05:41 AM
maddog56's Avatar
Were they similar builds? Seems like you'd have to have identical bikes to compare them or both in the same machine.
Old Jan 17, 2006 | 11:07 PM
Can some one give me some information on where to get these cams. Thanks
Old Jan 18, 2006 | 12:34 AM
UBETRUN's Avatar
Craycraft Racing's cam is only available from their shop, the rest of them are "off the shelf" and available through any builder.
