05 raptor 350 question!!
Old Jan 16, 2006 | 01:21 AM
lilhill's Avatar
Default 05 raptor 350 question!!
ok i really need help on this. i have a raptor 350 and i just got a yoshimura comp series slip on for it, now what else do i need to do to my quad so that it runs right with the new pipe?
Old Jan 16, 2006 | 02:03 AM
yamahammerrider's Avatar
did you only get the muffler or did you get a header to go with it?
Old Jan 16, 2006 | 02:08 AM
lilhill's Avatar
i didnt get the header
Old Jan 16, 2006 | 02:11 AM
y not it wouldve gave you alot more power. also now that im thinking about it you might want to call ur dealer and check if you need to re-jet it or not since you didnt get the header idk but you can nvr be to carefull. or did you get it re-jeted already?
Old Jan 16, 2006 | 02:17 AM
lilhill's Avatar
iii dunno just didnt, yeah they said we needed to re jet it, but i think i also have to do something to the air filter and mess with the idol a little bit buut im not suure
Old Jan 16, 2006 | 02:38 AM
im not sure about the air filter but the muffler can raise or lower you idle so....
Old Jan 16, 2006 | 02:40 AM
but w/e you do dont run ur quad w/o getting it re-jetted first bcuz you can run it to lean or to rich and mess ur motor all up.
Old Jan 16, 2006 | 09:24 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Rejet it with GYTR jets and have the carb tuned for the new pipe, than add on a GYTR air filter.
Old Jan 16, 2006 | 12:56 PM
Raptor350rider14's Avatar
get k and N airfilter and dyno jet.
Old Jan 16, 2006 | 07:19 PM
BONEshock's Avatar
You actually might not have to rejet. From the factory, most machines are jetted pretty rich. run it through the gears untill your topped out and check the plug. Should look like a nice tan to brown-ish. White is lean. Lean will give you a reason to go the a 430 stroker.
