Bore sizes
Old Jan 22, 2006 | 09:45 PM
YamahaRider8998's Avatar
Default Bore sizes
What does it mean when it refers to a 1 over and 2 over and so on. Im new on the bore kits and stuff so i need some help figuring out what they mean. I have a warrior, if i got 2 over what would it be and wat if i got 1 over?
steve
Old Jan 23, 2006 | 08:53 AM
Default Bore sizes
bump
Old Jan 23, 2006 | 09:54 PM
99MudKing's Avatar
Default Bore sizes
I'm not too sure about ATVs, but they may mean 1mm or 2mm over.
Old Jan 26, 2006 | 12:46 AM
rruser's Avatar
Default Bore sizes
If the bore of your motor gets warn out due to age or failure (like no oil), the piston can seize up and it leaves scrapes in the cylinder walls. The cylinder must be bored over (made bigger) to get rid of any deep scrapes left in the walls. Sometimes it just needs to be cleaned out with a hone. This was known when the motor was designed so that the whole cylinder does not need to be replaced. When you have the cylinder bored, a machine shop enlarges the bore up it up to the "next size over" in your case, your on the 2nd size over stock. The piston should say its size on the top. Like 0.50 or 1.0 0.50 would be .50MM over stock or "first over" 1.0 would be 1mm over stock or "second over" 4 stroke motors (like on your warrior) are pretty good on cylinders. You shouldn't have to bore it over unless something really bad happens (like you forget your air filter or have no oil). You can not go from a 2nd over back to 1st or stock without a new cylinder sleeve. You can buy big bore kits that come with bigger cylinder sleeves that can push the motor up to 430cc but its not something you can just install on your own.
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
