Raptor Glowing RED pipe normal?
leaner is meaner, the more lean you are the more power you make. although you should go up a jet size.
but my bike is jetted perfectly and dynoed(perfect) my jetting is spot on and my header still glows every once in a while. no big deal
a little is ok, but i mean if it is extremely red, and looks like if you poked it with a stick you could bend the metal, fatten up your jets.
I guess it depends on the machine. I have to be running way lean for my header to glow bright red, but I have a smaller motor pushing exhaust through a bigger pipe. I'd do a plug chop and use the results of that to make a decision. If the tip of the plug is white you should consider rejetting, if the tip is tan you're fine.
oliveiracarlos
09-07-2015 03:39 AM
