blaster starting problems
Old Jan 23, 2006 | 08:28 PM
inferno's Avatar
Default blaster starting problems
my friend has a 91 blaster it runs great it is probably the fastest blaster i have only rode well any ways it always has to be pull started when he first got it about a month ago used but in damn good shape for a 91 model does and body know why you cant kickstart it please reply as soon as possible
Old Jan 23, 2006 | 08:48 PM
Storj's Avatar
Have you checked the plug? It might be fouled also check the compresion make sure its at least up around 120psi or you might want to consider a rebuild. Also make sure its getting gas, make sure you use the choke when starting from cold. Make sure the carb isnt all gummed up.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
