Raptor wheels/ axle
I just put 20" razors on my raptor and there on banshee wheels which I off set and this gave the raptor 2-3inches wider in the back it works great and the razors let the raptor slide at highspeed around turns. So ya put banshee wheels on it and flip them around.
(01 yam raptor blue with full PRM skids, 11 tooth front sprocket, Renthal Fat Bars, Vortex Motion PRo twist throttle, Cr clutch perch and lever) soon I will be getting summit prm front bumper, graydonproline full exhaut, diff air filter and box, + 2 rear axle, +2 graydonproline swingarm, and ITP black beadlocks check them out under whitebrothers.com there cool!
the raptor wheels have the same offset as the banshee wheels. the raptor wheels are offset out already so it does no good to turn them around. if you put stock banshee wheels on a raptor with the valve stems out the raptor will be more narrow. if you put banshee wheels on with the valve stems in the raptor will be the width as with the stock wheels.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
