Did I ruin my Banshee's engine?
Old Jan 29, 2006 | 08:19 PM
82DuneBanshee's Avatar
Default Did I ruin my Banshee's engine?
I went to Glamis this weekend and while we were heading out to "The Wall" my Banshee started losing power, I thought I was in the wrong gear at first, but on the next dune I went down I gave it a blip of throttle and hear the engine rattling/clanging... i slowed to get a better listen and then say some smoke vapors for the left side of the cylinder head. I stopped immediately and the engine died, the guys I was riding with pulled up and immediately saw the problem... the radiant hose connection to the right side of the bike came off. My motor had overheated to the point where it no longer was able to run. I can kick start the bike and it idles fine, but once you give it gas it doesnt have any power.
Does anyone have any insight to make a guess how bad the motor is?
Old Jan 29, 2006 | 08:27 PM
midnite's Avatar
Well, you probily fried the rings and pistons. You might need your cylinders bored now also. Your cranK is probily ok, but check it out.
Old Jan 29, 2006 | 09:18 PM
basically an engine rebuild is in order sounds like...
Old Jan 29, 2006 | 10:32 PM
TheTurtle's Avatar
sounds like u need a new top end. while its apart why not throw in a stroker. then u will need new carbs to feed that mill. why not get new pipes to match the port work and such to make her really scream. just dont let the wife find out it wasnt all necessary.
Old Jan 29, 2006 | 11:45 PM
It currently has Trinity Racing Stave IV engine work on it, thats why its so dissappointing to lose the motor right now. It ran very strong, and was very fast.
Old Jan 30, 2006 | 12:12 AM
x2468's Avatar
pull the top off and take a look. change the pistons/rings and see what happens. if it idles, than i dont think you smashed ur low end.
Old Jan 30, 2006 | 12:41 AM
x2468's Avatar
oh, and since u say there was smoke from the side of the cylinder head then i'd say a new set of head gaskets is in order.
Old Jan 30, 2006 | 12:45 AM
Ok sounds good, doesnt sound like its going to be too bad after all. I am going to take it in this week after I find a good shop in Phoenix that does good/reliable engine work on Banshees.
Cole Hadden
Jun 15, 2025 09:05 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
