Raptor 660 starter problem
Old Jan 30, 2006 | 11:03 AM
hondarulesinnc's Avatar
Default Raptor 660 starter problem
My friend just bought a 2002 raptor and the starter turns over just fine but it is not catching on nothing.
Is this the one-way assyembley wore out? I looked on Ronnies.com and that was $179.
We took off the side cover and the large gear that is in the crank case will turn easly but will not catch on nothing, so I am assuming that the one-way is the problem. Am I right?
Can we fix that in our shop with common hand tools or does it take special tools or skills to fix?
Thanks for the help.
Derek
Old Jan 30, 2006 | 07:54 PM
maddog56's Avatar
www.raptortranny.com has all the information you need to change the one-way. That does sound like your problem, and it'll happen again if you buy an oem replacement one-way. You need one from L&A designs, they are sold by quite a few companies.
Old Jan 30, 2006 | 10:47 PM
smuznu's Avatar
The one-way is the culprite. (At least it sounds like it). I replace mine on my old raptor with a stock one and it only lasted about one year, then I had to replace it again. I suggest purchasing an after-market one-way, such as the one suggested by maddog56 (L&A).
Smuznu
Old Jan 31, 2006 | 04:19 AM
RaptorRookie's Avatar
I hate reading about these issues, it makes me worried that mine will go the next time I start up my Rappy. However, I have heard conflicting stories that in 04 this problem was solved. Can anyone confirm or deny that? I am lookin at gettin a stage 1 cam and head work, but if this starter issue is around the corner for me, I might buy the one-way before it goes out. Thanks for your input.
-Brandon
Old Jan 31, 2006 | 11:59 AM
rapman700's Avatar
Just fixxed the same problem last weekend easy to do. all you need is a steering wheel puller, impact gun helps on shaft nut, and a 12 pack perfeably Labatts
Old Jan 31, 2006 | 12:26 PM
1FastDS650's Avatar
Definitly sounds like the one way I just put a L&A Design in mine bought the kit from RSPconcepts.comRSP Concepts it came with gaskets, idler gear, and the one way. Very easy to install I used the temporary fix a couple of times using the rubber O-ring, just got tired of having to redo it. RaptorTranny has all the information that you need to replace it.
Old Jan 31, 2006 | 08:21 PM
maddog56's Avatar
-Brandon
The one-way was never solved. They beefed it up in 04 but it still fails about as easily as the 02-03 setup. My suggestion is to replace it as soon as you start hearing it spin free. Any riding you do after that leaves much more of a chance that the starter clutch will disintegrate into your oil, start dropping large fragments, or send a few busted bolts flying around your case.
toonces
Oct 16, 2019 12:11 PM
AtvManiac78
Jul 11, 2015 03:20 AM
tweeder
Jul 5, 2015 01:57 PM
DTroyer01
Jul 3, 2015 07:34 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
