Too much smoke
Old Feb 4, 2006 | 12:17 PM
1STXTIMERX's Avatar
Default Too much smoke
quick question, at idle there is way to much exhaust coming out. Do I adjust with the needle? or the air screw?
Old Feb 4, 2006 | 05:48 PM
420Pimp's Avatar
Could be your rings. Do you still have alot of compression? Try both skrews start with the idle screw.
Old Feb 4, 2006 | 06:17 PM
1STXTIMERX's Avatar
haven't checked rings, but I just want to elimnate it, it couldn't be caused by the main jet; at idle, correct?
Old Feb 5, 2006 | 01:19 AM
IdahoVinnie's Avatar
The main jet has no effect at idle.
Old Feb 5, 2006 | 12:37 PM
1STXTIMERX's Avatar
that is what I thought, but I was reading my Clymer manual and it says if there is excessive amount of smoke it would be neccesary to re-jet.. I was confunkled
Old Feb 5, 2006 | 03:56 PM
What color is the smoke? Black, white, or blue?
Old Feb 5, 2006 | 05:13 PM
1STXTIMERX's Avatar
heavy white
Old Feb 5, 2006 | 05:20 PM
heavy white
Someone correct me if I'm wrong, but heavy white smoke is usually an indication of antifreeze.
Black is fuel, and blue is oil.
Old Feb 6, 2006 | 12:37 AM
420Pimp's Avatar
If the black was cracked and antifreez was seeping threw you would probaly lose compression and it you would hear a weird noise from your head. Correct me if i'm wrong. But as for black, white and blue smoke i think your right. Thoe i never heard about antifreez burning white. But i'm not sure.
Bump
Old Feb 6, 2006 | 12:38 AM
420Pimp's Avatar
block
