how do you tell what year yfz 450 it is?
Old Feb 8, 2006 | 02:28 PM
JOEYG's Avatar
Default how do you tell what year yfz 450 it is?
just wondering how to id the year of the atv. thanks
Old Feb 8, 2006 | 06:23 PM
135boom's Avatar
04-05 are practically the same. THOUGH, there are ways of finding the differences. IN 04, the graphics were of course different, and it came with the standard greenish steel shifter and rear brake pedal. It also has a plastic plug on the right side of the motor, where the decompression linkage would go on the dirt bike. Its up above the header, near the top front.
IN 05, it came with different graphics, and came with aluminum shifter and rear brake pedal. It also has (instead of the plastic plug for the decomp), a molded over permanent cap in place.
THose are the only ways to really tell for those years. I dont think you could tell the seat difference.
In 06 they have new graphics, but more noticably has a completely new swingarm with cam style adjustment, a dual piston rear caliper, aluminum front and rear grab bars, a LED rear tail light, a MUCH thicker seat with silver coloring down the side, and if you got blue, the a-arms too are blue. If you got white, they are silver, aliong with the rest of the frame.....which is different then 04-05 as the white one had a candy apple frame.
In short, if you want to quickly see the difference in 04-05, then look for the shifter and brake pedal. If you want to see the difference between the 06 and the 04/05 then look for any of the above, as its quit obvious!!
Hope that helped!
Old Feb 8, 2006 | 07:28 PM
smb05's Avatar
JOEYG,
Look at the tenth digit or letter in the Vin#.
VIN Character - Model Year Codes
1971 1972 1973 1974 1975 1976 1977 1978 1979 1980
1 2 3 4 5 6 7 8 9 A
1981 1982 1983 1984 1985 1986 1987 1988 1989 1990
B C D E F G H J K L
1991 1992 1993 1994 1995 1996 1997 1998 1999 2000
M N P R S T V W X Y
2001 2002 2003 2004 2005 2006 2007 2008 2009 2010
1 2 3 4 5 6 7 8 9 A
Good Luck.
SB
Sorry the chart did not go as planned
Go here Vin Number
JohnnySplat
Aug 6, 2015 12:07 PM
Mikesohio
Jul 26, 2015 10:51 AM
Bratman2
Jul 25, 2015 07:16 PM
baysport
Jul 23, 2015 11:37 AM
black_thunder
Jul 12, 2015 11:04 PM
