Anohter TORS ? 94 banshee
Old Feb 9, 2006 | 12:20 AM
2000IAWarrior's Avatar
Default Anohter TORS ? 94 banshee
ok.. what again is TORS.. and also.. if it just isnt connected on my banshee will it hurt it? what if someone cut the wires.. they r bare and touch eachother.. the ones on the carbs.. and the ones comin out of the throttle? j/w..
Old Feb 9, 2006 | 12:24 AM
also would this be the reason why my banshee is hard to start? well one of the reasons?
Old Feb 9, 2006 | 12:42 AM
Ernie660R's Avatar
Buy a TORS elimenator kit from 1dirracing.com
Old Feb 9, 2006 | 02:31 AM
midnite's Avatar
Hard starting when cold is a sign of low compression. When the motor warms up and the pistons expand it makes a tighter seal and less compression slips by the rings. So when it's warm then it's easy to start. Check your compression. Anything less than115psi at sea level is re-ring time.
Old Feb 9, 2006 | 09:55 AM
never thought about that.. i did a comp check once.. and it was like 130-140... but i cant rember if it was warm... ill have to do a cold comp check... probly is time to rebuild it.... ne were i cna get a cheap rebuild kit? top end that is
Old Feb 9, 2006 | 01:42 PM
midnite's Avatar
Rmatv.com has good prices on the wiesco pro lite pistons, rings and gasket kit. Around $175.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
315blaster
Aug 8, 2015 08:13 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
