would u trade warrior for banshee
Old Feb 13, 2006 | 04:03 PM
warriorboy22's Avatar
Default would u trade warrior for banshee
this is the second time i have been offered to trade my warrior for a 2001 banshee with fmf pipes reeds uni filter after market everything except the supnsion and it is bored 40 over brand new top end rebuild as well with brand new piston and stuff.
here is the downside only one exaugst has fumes coming out the other has barely any(says it need new reeds). that carbs need new jets and he needs strating fluid to start it
he said he put his friends stock carb and reeds on it and it ran perfect.
the quad has alot of hours on it because this was the kids main quad.
he said if i pay for it to be fixed and it has more problems we can trade back and he will sell his fmf pipes to pay me back
Old Feb 13, 2006 | 04:57 PM
DavidLT250S's Avatar
is the bike tired?? usually 2 stroke that have alot of hours on them are tired...if it runs strong and is it good shape i say go for it but keep in mind thats banshees need alot more maintnence then your warrior but its worth it because they are sick bikes. check the frame, swing arm, and a-arms for cracks and bends too.
Old Feb 13, 2006 | 05:03 PM
the top left a-arm was bent but stratened u cant even tell the tires are peerectly strait but u can see were it was bent
what do you meen by tired. he said that when he put his friends stock carbs and reeds the bike ran strong
And he told me the bike is alot of maintance so i believe it. as long as the bike is not so unreliable that everytime i ride it i have to fix somthing
the front fenders are shaved off and his rear rims are bent.
but what about value wise is it worth it?
Old Feb 13, 2006 | 05:52 PM
recon99's Avatar
I don't know if I would believe that he switched those parts with his friend's and it ran perfect. For one thing, jets don't go bad or wear out. There's no reason to replace a jet unless it's not jetted properly. Does he have any reciepts to prove that the top end was rebuilt?
Honestly I wouldn't trade my warrior for a banshee, because you'll probably be fixing or replacing something else after every ride. I don't know anybody that has a banshee that went for more than a month at a time without needing something replaced. If you really think it's worth it then take the offer, but i'd never trade a good running quad for one that's in worse shape, older, and doesn't run right.
Old Feb 13, 2006 | 06:43 PM
yes he has recipts for everything but this bike was ridin really hard so im not sure if i want to trade i think i might just wait a month to sell my bike and buy a brand new banshee or 700r or somthing
Old Feb 13, 2006 | 08:23 PM
midnite's Avatar
Doesn't sound like a fresh motor to me. If you really want the shee, be prepared to put in new rings and pistons.
Old Feb 13, 2006 | 08:39 PM
recon99's Avatar
That sounds like a better idea than trading. If it's been beat you can plan on spending most of your free time fixing it and getting towed back home. From the way you described it the top end needs rebuilt again. I have a feeling one cylinder is pretty f'd up if it's barely firing, and it takes starting fluid to fire it up.
95wolv
Sep 27, 2024 12:00 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
