Sparks header glowing...rich/lean?
Old Feb 20, 2006 | 07:55 PM
fizzak's Avatar
Default Sparks header glowing...rich/lean?
I just installed a Sparks X6 on the Rappy. It glows with a faint red while full warmed up idle. My Edelbrock is tuned for a stock pipe and I have not yet dialed the needle in for the Sparks. Would this indicate a rich, very rich or lean condition? Or is this normal? It runs very strong right now. I'm at about 1200ft elevation and temp here is 34°f.
Old Feb 20, 2006 | 08:05 PM
DriverDoyle's Avatar
If your header is glowing red...Your lean....But you said it is a faint red...so you mite just be a little lean....And if its only doing it at a idle....Go up one size on your pilot jet....It will not hurt anything to be a little fat...Its better to be a little fat than lean...But if its not like glowing Bright red...your not too bad.....
Pull your plug....You want it to be a light brown....If it is white your lean....And if you get it to rich it will be wet and black
Old Feb 20, 2006 | 08:16 PM
fizzak's Avatar
Thanks for the quick reply. Im not used to tuning non-computer controlled engines believe it or not. My carb has no jets, all I have to do is turn a dial on the top on the carb a click or two rich or until the header stop glowing I guess. I love that carb. I would really like to install an O2 sensor, I could tune it perfectly. Has anyone tried this?
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
