spring load
Old Feb 20, 2006 | 08:09 PM
jaggers2e42's Avatar
Default spring load
i'm confused on the topic.is it the more spring the softer the ride or do i have it backwards.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 20, 2006 | 08:46 PM
Default spring load
hmmmm.could be a bad sign
Old Feb 20, 2006 | 08:54 PM
recon99's Avatar
Default spring load
a lower preload setting will give you a softer ride, high preload gives you a bumpier ride, but won't bottom out as easily, and the front end sits a couple inches higher for more ground clearance.
Old Feb 20, 2006 | 09:02 PM
IdahoVinnie's Avatar
Default spring load
I'm not really sure what you are asking, but let me say this: I used to run a stock car. To lower the car, we could cut a coil off of the spring. This lowered the car, but it had a stiffer ride.
Dewhound
Apr 20, 2017 02:25 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
