My Raptor died....
#22
If you've got a compression guage you can check for that. If you have a bent exhuast valve it should still start but run very badly. If you don't have a compression guage, you'll need to rig up a hose of sorts and figure a way to seal it at the spark plug hole and blow into the tube by mouth. If there is no back pressure you have a bent valve or two, or three. Are you sure it's getting fuel?
#26
Then it's got to be a timing thing.
Check TDC the old fashioned way. With somthing in the spark plug hole going up and down with the piston, watch the timing marks on the flywheel and case. See if it realy is TDC when the marks line up. Did you blow into the spark plug hole yet? Put it at TDC and try it. You will know for sure if a valve is bent or not when you try it.
#29
CTracingraptor...this is killing me...i know what your going though..Austin had a aftermarket CDI just laying around..But i think he just sold it on ebay...I would have sent it to you just to help figure out what it is.....
