100psi...should I change?
Old Nov 11, 2000 | 08:37 PM
Zorro's Avatar
Just measured ny shee's compression today. It was like 5 degrees (celsius)...I don't know what altitude, but not much (montreal).
The gizmo climbed up to 80 after 3-4 kicks and slowly to 100psi...and then the pressure would go down. Should I blame the gizmo measurer for the pressure diminishing, or is something wrong inside (I would go for the gizmo's fault).
Anyway, do you guys think I should change my rings, or pistons?
Thanks
PS. Even with loctited nuts, the disc and sprocket get loose, the twist is cool, and K&N is great.
Old Nov 11, 2000 | 09:36 PM
chriscoll1's Avatar
You need a top end rebuild.It should hit 150lbs after 2-4 kicks.
Old Nov 11, 2000 | 10:01 PM
Xplor's Avatar
You climbed too many hills man...
Old Nov 11, 2000 | 11:19 PM
brokemybanshee's Avatar
Can you still kick start it? My ex banshee with one piston that was scratched to crap along w/cylinder had around 118 or so.. with ONE PISTON!
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
