Oil wieght recomendations??
Just wondering what kind of oil you guys are running in your 4 strokes. I live in Wilmington North Carolina. Its semi humid here and 40 degree nights with 70-90 degree days. THanks for the help!
Depends on the grade. My quad calls for an API SF or SG grade, API SH or SJ with JASO MA.
I personally run 15/40 Rotella in everything that takes oil. I use it in everything from a lawnmower to 600HP small block chevys to even diesels. It is rated for everything I own; if I remember right I think it is a SJ rated oil. It's an inexpensive oil and I don't have to have 5 different oils laying around. Never had an oil issue in any of my engines.
Not knowing how much riding you do, I would say use about a 20/40 SAE. If you stay above the 20 degrees, this oil should be fine with good protection for the occasional cold days.
I also use the yama-lube from the yamaha dealers. It may be $1 more then another type, but i haven't found another brand yet.
[quote]
Originally posted by: Budwiser
Not knowing how much riding you do, I would say use about a 20/40 SAE. If you stay above the 20 degrees, this oil should be fine with good protection for the occasional cold days.q]
20/40??? That doesn't sound right. At 20 degrees out that's pretty thick stuff to be pumping thru a cold bike. No manuals (or mechanics I know) recomend 20 weight below freezing...
