What gearing for Blaster?
Old Nov 12, 2000 | 09:57 PM
jtblstr247's Avatar
Is there better gearing for a Blaster than the stock gearing to make it go faster, could you tell me what mods you got on yours. Thanks for any replies.
Old Nov 14, 2000 | 11:09 PM
blastinblaster's Avatar
when i first got my blaster the first 3 gears were fine. then i put the power piston in it form vito's and the first 3 gears wound out real quick. so now i use a 14 tooth front sproket and it does just fine
98'blaster power piston , 14 tooth front sproket
modified air box lid
Old Nov 15, 2000 | 12:41 AM
yamblaster1995's Avatar
when I modified the gearing on my blaster I changed it from 40 teeth on the back sprocket to 38. And the front I changed from 13 to 14. I do not reccommend this because it bogs in 4th and 6th gear. I changed the front sprocket back to 13 teeth and it is now a little faster and it gets up to speed just as fast as before.
John Reed
Sep 9, 2015 03:46 AM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
