HeLp!!! Compression Death!!! HeLp!!!
Old Mar 11, 2006 | 09:38 AM
tuckercapo's Avatar
Default HeLp!!! Compression Death!!! HeLp!!!
I am trying to figure out what lbs is acceptable for a 2004 Bruin 350 engine. I finally found a quad for my family so we can ride. It looks a little dogged and has little compression I am going to run a compression test but have no idea what is acceptable. Thanks
Old Mar 11, 2006 | 11:49 AM
recon99's Avatar
Standard is 121 psi, minimum is 114, max is 128.
Old Mar 11, 2006 | 12:25 PM
ddrumman2004's Avatar
One thing I suggest is to switch the oil to a synthetic. My g/f's 04 Bruin started burning oil on start-up due to worn valve guides no doubt and when I switched from Yamalube to Amsoil 0w-40 atv oil...the smoking stopped. The engine runs smoother and idles a hair faster.
The oil ain't cheap but neither is rebuilding a Bruin engine and oil is the lifeblood of any engine.
Scooter's Shop
Oct 9, 2015 02:09 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
